When creating IFC files I have a some issue. I'm creating corridor using corridor modeling and then I use a tool "Place Node" to add some surrounding infrastructure. Before using tool "export to IFC" I'm changing all designed Nodes with tool "mesh from element" to mesh elements (only mesh elements could be exported to IFC file). Unfortunately many of them doesn't show in IFC file. For example I'll put screen with added node in ORD, displays correctly , and below screen from BIMVision, where only some elements of this node exported to IFC file. Maybye someone has experience with this kind of troubles while creating IFC files.
Do you have access to https://review.itwin.bentley.com/home ?
It exports everything from the DGN (at least for what I did until now). So main possible issues are:
