HI Everyone. We are working with Power Rail Track SS2 (mandatory) and the process to show the stripping on the Cross Sections is higlhy time consuming: After calculating earthwords footprints, we create several surfaces under these footprints depending on the stripping depth . Then, we drop the surface the amount of the stripping and we depict it on the x sections.
But, if the plan or profile change, the process begins agin from scratc. Other softwares have a simple instruction to show and measure the stripping automatically under the footprint.
Does anyone know if there is a simple instruction in SS2 like that?
Is there any easier way to generate the strippings?
Thanks and have a nice day.
Did you have a look on the stripping/overlay component in the template ?
Hi Jpln. We are trying to soilve it with the Itl and i is working . Thanks for your advice.
