When I import the alg into open rail, it automatically changes the Cant value and the cant calculation parameters to standard gauge even though the settings of the open rail are set to Broad Gauge.
Hi, we have noticed that the circular data within the algs is defined as chord not as arc although you have designed it with the arc definition setting when you import the alg, the analyze point tool in OpenRail gives you a wrong value on the circular elements and a wrong annotation. I suggest you export your alignment to XML format from PowerRail, once you have created the XML file, open it with a text processor, use a processor with a tool for finding and replacing, and find chord, and replace with arc. finally, create your OpenRail alignment from XML file.
Manuel Soriano I have never seen what you are describing above when importing ALGs. Do you have an example ?
Sure, I share the ALG file
LOT 3_UPDATE.rar
I can't replicate the issue using the ALG. Radius looks good using Analyze point or Measure Arc and are matching with the report and the ALG.
