Hi There,
I would like to annotate an alignment such that a tick shows up every metre. At the moment, if I run the "Element Annotation" comment, it annotates with major ticks every 100m, and minor ticks every 10m.
Does anyone know how to change this setting in OpenRail? It was really easy to do so in Rail track, with the option to set major and minor ticks when annotating.
I've been going into feature definitions etc. and could change the line weights, colours etc. However, I couldn't see anything to alter the ticks / stationing.
I also tried working around with the civil labeler, but didn't have luck with that either.
Please let me know if there is a good way to make this work.
Thank you
Actually, after some more stumbling around, I think I've found the answer with this video from the Bentley Hong Kong team.
https://www.youtube.com/watch?v=-4ds7QoS5Qk
If anyone has some further insights, I would still be interested.
The video looks pretty good and shows the settings. For automatic annotation use Annotation Group.
