Uso OpenRail designer 2022 R1 y cuando quiero colocar las traviesas, salen desplazadas hacia adelante respecto a los rieles. desplazando también los rieles largos sobre los desvíos, comparto el archivo en enlace de wetransfer
https://we.tl/t-ht76pgBAjl
It looks to be a bug in 2022R1 due to the profile not starting at beginning of horizontal. When I lengthen the profile to the start of horizontal sleepers are created correctly.
It looks to be fixed in upcoming release 2022R2
Thanks a lot, Jean Pierre, with your answer I know how to fix it. But I think that it is a bug in both the 2021R2 and 2022R1 versions, I thought that it was a bug in the 2021R2 version then I tried with the 2022R1 version with the same mistake.
