Hi
I am working with Bently InRoads Suite V8i(SE LECTseries 10).
I put Default Grid Factor for the alignment design. (see below screenshot)
When I print out XML reports I got "Input Grid Factor" in the old version of InRoads
But the new version is Bently InRoads Suite V8i(SE LECTseries 10). It is not shown Input Grid Factor.
Please advise to me of the reason.
Daniel Kim
As I can see Input Grid factor is still output in the XML report so is available through the XSL.Did something changed in your report? Is one from SS2 upgraded to SS10?
It looks like it is not in the delivered XSL.
You can add:
<tr> <th align="right" lang="en">Input grid factor:  </th> <td align="left" colspan="2"> <xsl:value-of select="@inputGridScaleFactor"/> </td> </tr>
