Hello Everyone.
I imported rail turnout library according the link:(+) Rail turnout import key in - OpenRail Forum - OpenRail - Bentley Communities
But I can not import Double Slip turnouts.
Did you have similar problems?
Mikołaj Belter
I don't remember any issue. As fat as I know double slip turnouts delivered with the software have been imported using the command.
What is happening? Nothing is coming? Error?
Hello, yes indeed, nothing is coming. Please see below. on the right I have printscreen from Rail Track SS2, on the left imported to Open Rail, from xml file. I havn't got Double Slip folder in Open Rail. And in defult version of "Rail Settings Features Annotations Levels Elem Temp Metric.dgnlib" we also had not folder for double slip turnouts.
Ok understood. You will find it in Crossing folder (diamond, single slip and double slip)
Thank you JPLN :)
Answer Verified By: jpln
