Hello everyone,
I would like to know how to create a cant for a template with double track (see the image below) :
And the cant should be applied as follow (according to french standards) :
PS : I'm using OpenRail Designer 2022 R1
Cant application by itself cannot create this automatically. But you can get this using a template. See attached ITL and PDFs.
It has been done for Rail Track but still applicable to OpenRail.
RFF Double Voie par ZP (IN3278 tiers dévers).zip
I will check the attached files and get back to you after testing it.
Thank you
