Hi guys,
I'm currently working with this template, observe the selected Line component, it has two ends right and left as marked below.
Issue #1
My goal is to project the line ends to the tunnel inner ring. The level of this line will vary depending upon received survey data, hence the length of the line will by dynamic.
I'm using "Project to Design" with "Closest Component" option. I'm specifying positive value at Right end and Negative value at Left end, The screenshot below is for the Right End:
But this is not working as per my requirement:
Issue #2
The Tunnel component is Perfectly circular in Template but It is rendering as Polygon in 3D and Cross-section view, hence even if the Issue #1 get resolved I doubt this will cause an error with the length of the line, I hope you get my point.
Any workaround for these?
My OpenRail version : 2021R2
I successfully projected to component in 2022R1 so don't know if there are some issues data specific or due to 2021R2. You may share the file or create a Service Request so that support team can investigate.
We don't use arcs to extrude component mesh. Arcs help creating the template that's all for now. We are using stroking variable to describe the arc as linestring:
