hi all,
im traying to create conic slopes with the dedicated tool in model detailing. its omposible for me make the slope have the slope that I want. I tried changing the slope format in civil formatting but is completely impossible.
some one had the same problem or an idea what is happening?
and testing the tool in a flat terrain I noticed that the angle between the two lines afect how the cone look. if the angle is less that 90º the result is sharpen and if its more that 90º the result is blunt.
only made the expected result is the angle is 90º
thanks in advance
Did you watch this video Video: Create Conic Slope tool in OpenRoads Designer - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities ?
It depends on parameters used to create the conic slope.I don't see any issue from my side but haven't tried all possible settings.
hi,I have the same problem, I can't build the cone with the slope that I want, I tell it to do it with a 50% slope and it doesn't build it well, I don't know what I'm doing wrong, here you can see that the slope that I indicated that I build is 50%, my corridor has that slope, but it does not coincide with that of the cone
I did few tests with 2022R3 and didn't find any issue whatever the method (primary or secondary elevation, or fixed elevation).
hi, did you try to do the cone with a different agle than 90º?
