It seems there is no ArcGis import inside OpenRail Designer 2022 R2?
Is there a backdoor to get it inside OpenRail?
//Christiaan
It's only a keyin for now (I believe its in technical preview). I am guessing they add a button next release.
Keyin:
mdl load Bentley.ArcGIS.dll;featureservice import
Answer Verified By: Christiaan Post
Check Key-in works, but it does not import anything as I can see?
I am not sure the issues are related, but it appears that they did not build in authentication for ESRI. So, any non public REST source will need a token.... HUGE PITA... Hopefully they fix this ASAP
