Good afternoon,
i am wanting to extract offset information from my track to a large volume of 3D elements. All i want is the closest offset to the rail and the maximum height above rail.
is there a way i can do this without manually measuring each element along the track?
e.g for the attached image i want to report the top rail (blue) to the structures (red) maybe every couple metres.
I would like to do this in Microstation Connect edition or Openrail Designer. Have the option of Power Rail Track as well.
The best is to use station base report. There is an issue with elevation in current OpenRail 2022 release that is fixed in the upcoming release. Meanwhile you can use PowerRail Track or OpenRail and station offset report with small interval. With this one interval is measured along offset feature.
