Hi
With the implementation of IFC 4.3, how soon we can utilize this in ORD?
I understand with this feature we can directly export in IFC 4.3 and Import in Revit as parametric objects.
Pls confirm.
IFC 4.3 is already available in OpenRail
iTwin platform is even usually better to export to IFC because of frequent updates.
However being able to export to IFC and being able to get some parametric objects in IFC is a different story.Except if you mean "set of properties". In this case it does work.
Now we can also use classfication in OpenRail to better manage models.
