Hi.
I have done a library of element templates, feature symbology and feature definition using the migration tools.
Everything is working as it should, except feature definitions for meshes where it’s not able to reference to the related symbology.
When I try to manually change the reference in the feature definition and do a export, I have exactly the same as I had in the input.
I receive no error message when I try doing this.
What version of OpenRail are you using?
Hi, Currently I am running OpenRail 2022R3.
It prompts this error when I import.
Unfortunately I am sure this is one of feature definition object that has changed from version to version.It is probably why it can not import.
Did you compare the XML files or just Excel files ?
I suspect that the XML generated by the migration tools is incorrect.
