Hi everyone,
I am trying to import a tif file to an ORD file. But the program categorically refuses to do so?
I tried with files that have defined and undefined coordinates, 2D and 3D but nothing seems to work.
Does anyone have any suggestions?
PS I try to do it through terrain tab.
Best regards,
Filipp Zarov
hello,
I would submit to support so that they can have a look if there is a bug or limitation regarding the size of the tif, or an issue with th etif itself.
I just tested with an old tif 3 millions points and it did work perfectly in few seconds.
Can you clarify if you mean import or reference. For tiff files depending on the size i would suggest referencing.
