Hi Mikko,
The report XSL themselves can be edited to provide stations/units to whatever you want. This may be the best option for what you need currently.
Mark
Yes. Currently the only available solution.
Thanks to Paul, my colleague, who provided few examples:
eg if the station is 10,000.000 then
<xsl:value-of select="format-number(number(Start/station/@externalStation),'##+###.000')"/>
will output 10+000.000
or
<xsl:value-of select="format-number(number(Start/station/@externalStation),'##km ###.000')"/>
will output 10km 000.000
<xsl:value-of select="format-number(number(Start/station/@externalStation),'#.000')"/>
will output 10000.000
Thanks Mark and jpln !
I am not familiar with editing XSL and as I tried to put the above examples to the code, I couldn't get right results. As default, my code looks like this:
<xsl:value-of select="cif:stationFormat(number(GeometryPoint/station/@externalStation), string(GeometryPoint/station/@externalStationName))"/>
I tried to put the "'##+###.000'" several different ways, but didn't have success. Below example:
<xsl:value-of select="cif:stationFormat(number(GeometryPoint/station/@externalStation),'##+###.000')"/>
What I am doing wrong here? It seems that xsl doesn't recognize hash symbol as a reference for the corresponding station values.
Is there any "XSL for dummies" -guide specifically for OpenRoads/-Rail users?
Br,Mikko
You are very close. Instead of:
change to:
<xsl:value-of select='format-number(number(GeometryPoint/station/@externalStation), "##+###.000")'/>
Thanks again, but still not showing right:Br,Mikko
