When I print in cross sections, it displays all of the template points with black circles, see the snip below. Is there a way I can fix this? Am I using a wrong setting?
I have turned fill off in both the sheet view and in the printing to try and get rid of the filled black dots. in the CAD there are no black dots at all, it is only when I print to pdf.
Ryan
did you try to turn off Line Weight in print attributes?
I have just tried this, it is the same result. I have been selecting all elements within the cross sections and I believe that each of the dots are '3D linear elements' produced in the 3D model, where the 3D alignment follows the template points. I cannot figure out a way to turn them off. Any thoughts?
