Greetings everyone, I am trying to create two profile lines which describe the upper and lower surface of a tunnel.I tried to use quick profile from surface, as well as profile by 3D element but it does not seem to work. Tried also with dgn and dwg, as reference or merge into master.
Am I missing something? Should one begin from a 2D or a 3D view? What are the requirements?
The model used as a base is a 3D describing a tunnel for metro.
Thank you in advance.
Filipp Zarov
If you have edges in the provided mesh/solid that are representing upper/lower surface where you want (along Alignment), then we can import mesh/solid and extract edge and use.
If you want to create profile on surface, then you must import mesh (or solid that you wil have to convert to mesh) and add feature definition.
2 options in mind, 1 is certainly the best:
Thank you Jean-Pierre for the answer. It seems kinda troublesome when it comes to the format of the files one imports in ORD in order to get som specific functionality. Sometimes, coversion is required. But I think you answer is satisfying.
In addition, you could convert the object to a Mesh (if it isn't already) and assign a feature definition with a "Design" Volume type. You can then use the "Terrain from Design Meshes" tool to automatically get a top and bottom Terrain.
Mark
Answer Verified By: Filipp Zarov
