Not Snapping with Micro station elements
Dear all,
I am using BRT V8i with microstaion V8i Select services-2 in the i am facing a small prblem i.e when i am using BRT command Like Move PI,Insert Pi when moving the geometry Alignment if i use microstation snaping tools to snap with end point.to microstation element i.e not snapping with. i autocad i can use snap tool(which provided in BRT) But in Microstation i am unabble to snap. can u pls give me reply for this problem.
Thankks
Jac
Parents Reply Children
