Hi Firendzzzzzzzzzz,
I am having a Problem in Plan and Profile Generation. i.e i want to generate Plan and profile with the scale of H:1:2000,V:1:500.
I am Generating profile with the exact scale. But Plan is geneating only 1:1000 or 1:1. I want to generate Plan also 1:2000 or 1:0.5
Present i am changeing text height only but i dont want to change the text height. i want to change the plan scale.
Please friends kindly help me how can i generate plan also with the same scale..
Thanks and Regards
Zakeer
Thank you.
Thank you for your Work flow. I used to do the same method. What I need is to generate the plan with 1:2000. means it should display 5m(1:1000) as 2.5 m(1:2000). when i measure in the plan it will be only 2.5m(but the chainage diff. is 5m). befor printing the drawing. I dont want to change the Profile Exaggeration it will be only H1:0.5 and V1:2 only...
THANK YOU FOR THE REPLY I WILL DO LIKE THIS ONLY
Jakeer
