Does anyone have a sample of a Station, Speed and Cant Table?
The help file only sates the following ...
specifies the applied cant and design speed are defined in a file. The format of the file is station, design speed, applied cant. The design speed is either kmph or mph, applied cant is either millimeters or inches.
Are you supposed to use the station, speed and cant at each transition?
For example, would it look like this without the point labels?
Station V Ea
TS 3+00.00 39 0
SC 3+31.00 39 1.5
CS 4+31.00 39 1.5
ST 4+62.00 39 0
Hi
My data are formatted as follows
Stn speed cant
116422.043 160.9 125
116514.878 160.9 125
116545.347 160.9 125
116581.568 160.9 125
Yes a value is needed on every element or else it does not show the correct cant deficiency so check your output at virtual transitions and add 1mm to the station if necessary.
HTH
Mike
