Hi Bentley Users
I have a problem with my annotation of a profile where I need Horizontal Slew on - but table comes up emty.
I have used it many times throughout the years, but I don't know whats wrong now.
I have an alignment with all the regression point associated, so it is not because of that. The vertical slew works perfectly based on the same regression points.
In the alignment file I have about 20 geometries and the preference works on all of them, except 2 - So I'm lost with this problem.
Have anyone any idea whats wrong? I'm running all the newest versions of MS and BRailTrack
Please let me know if you need the xin- and alg-file to look at.
Kind Regards
Martin Laursen
Hi Martin,
You look to be an experienced user and the problem you describe is not easy to analyze without the data and maybe the XIN file. I advise to fill a service ticket and attah the data (ALG+XIN).
Best Regards
JPLN
Hi
I may have found the problem - See question to Bradshaw on this thread:
communities.bentley.com/.../37592.aspx
I think the problem has something to do with the direction of import of reggression points (A-Z) and that the direction of the alignment must be the same at the points (A-Z).
If they are not, A-Z vs. Z-A, then the fail is there.
Thanks for sharing it helped me.
