Hallo, i want to create a surface in the roadway modeler using an alternative surface option.But I want this surface to be perpendicular to the profile. For example the point for the alternative surface is at 1m distance from the vertical alignment, I want the alternative surface to be perpendicular to the profile at one meter elevation. As a result the elevation at that a particular station will be little more taking into consideration the vertical slope. Is it possible to do that in the road way modeler or is there any other function. Thank you for your help.
hello,
I don't see any way to use the longitudinal slope in the Roadway designer. It would mean creating points before/after the current cross section location. I don't know exactly what you want to achieve but If you really need only this line at a perpendicular offset from the ground, then you can:
Hallo JPLN
Thank you for the quick response and for the great advice. It works well. I believe that it is the only way out. Thank you.
Best Regards
ygirma
