Hi.
They have asked me for a rail project to model an alignment
I want to do this in SS3 but now I run into the following problem. I want a radius between two elements with a fixed radius and a fixed length.
the radius is 10000m, a length about 12m Does anyone have an idea how to model these?
Thanks in advance
CP
The best way is to export this to an alg.file and use it inside BRT or PowerRail TRack (SS2) with the Multiple Element Regression Analysis. Here you can set the degrees of freedom for any element you want
Gunnar
Hmm Bentley Railtrack doesn't work good at the moment.
