I'm having issues creating a custom vehicle and have not found any thread helpful on this matter. I've followed the instructions to create the control points but I cannot create a section I drew a shape in the model and it says successful completion but it does not go to the xml.
Let have a look on this communities.bentley.com/.../198028.aspx
It includes a DGN used to setup new vehicle
Looking through it that is what I had set up, vertical shapes and points along the 0 z axis. I have an issue with having Rail Track take the shape and record it as a section.
I worked with Swept Path some times ago and found it easier to editing the xml-file for vehicle definitions directly. Once you found out the logic regarding the sections, distance between Bogies and Sections, then it is fairly straight forward. Good Luck!
LiPeng, Denmark
It looks like files have been moved in a different location.
http://communities.bentley.com/products/rail_design/le_rail_en_france/m/le_rail_en_france-files
