Tech Talk: Stability Consideration, Tension and Compression Presenter: Surojit Ghosh, Senior Structural Engineer, Bentley Systems Date/Time: 10th June, 11:00 AM IST (GMT + 5:30)
REGISTER NOW
This session is the first in a series of four on Steel Design to IS800:2007 with STAAD.Pro CONNECT Edition. Learn about selection of analysis method and stability analysis based on Section 4 and Annex B. We will also discuss section classification and slender section design, and cover design of tension and compression members.
During this session, you will learn:
The STAAD Tech Talk is open to all Bentley users, so invite your colleagues!
