Title: Answer Hour: Consideration of Shear Wall-Frame Interaction in BuildingsPresenters: Sanjib Das, Manager, Technical Support, Structural, Design Integration Analysis, Bentley Systems, Inc., Shreyanka Bhattacharjee, Technical Support Engineer I, Structural, Bentley Systems, Inc. and Abhisek Mandal, Technical Support Engineer Structural ,Design Integration Analysis, Bentley Systems, Inc.
Available On Demand
Answer Hour programs are virtual sessions about support topics that are currently trending.
Shear Walls are an integral part of lateral load resisting system in buildings. Their interaction with frames and allocation requires a detailed study. Design aspects of these walls are quite important.
This session will cover these aspects in detail:
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
