Title: Coffee Corner: Structural SEAPAC - Integrated and Standalone Steel Connection Design with RAM ConnectionPresenter: Sapath Rajbhandari, Application Engineer, Engineering Simulation, Bentley Systems and Madhan Elumalai, Senior Technical Manager, Bentley Systems, Inc.Date and Time: Thursday, November 25, 2021 at 11:00 am SGT
Register Now!
In this session we shall look into the integrated connection design workflow using RAM Connection and STAAD.Pro as well as standalone connection design with RAM Connection. A brief update on some of the latest features will also be presented.
Connection Design performed for a structure requires input of joint forces, which are calculated through structural analysis. In projects with large number of load cases and joints, the process of extracting all the required data and using it to perform connection design can be time consuming and prone to errors.
Integration of RAM Connection with STAAD.Pro automates the input process based on the results of structural analysis and saves precious time for the user. Even when used as a standalone program, RAM Connection offers many beniftits over hand calculations and spreadsheets.
Bentley Structural Coffee Corners for SEAPAC are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
