A new update to the CONNECT Edition of the popular STAAD.Pro analysis and design application has been published and is now available. As part of our commitment to you to deliver new builds more frequently, we are making available this build which addresses a number of issues that have been reported and thus highly recommended that you adopt this new build.
STAAD.Pro CONNECT Edition Version 22 Update 9
Key updates include:
and much more.
For more details see New Release - STAAD.Pro CONNECT Edition V22 Update 9 (22.09.00) - RAM | STAAD Blog - RAM | STAAD - Bentley Communities
Details of the Revision History can be found here:-
What's New in STAAD.Pro CONNECT Edition V22 Update 9 - RAM | STAAD Wiki - RAM | STAAD - Bentley Communities
Dear calrlos
We have many issue in staad pro, you must update or rearrange software, to compete other software like Etabs, midad, prota...
Some issue like
1.remove staad advance foundation and upgrade RCDC by including RCDC FE
2.Drawing of steel too shame by steel autodrafter, make software drawing steel member with connection together.
3.some of feature in staad pro not interested you can remove it like design
4.add some feature for easily exchange like revit,other software
5.many other ting i dont remember now
Thank you for you feedback. As I am sure you appreciate STAAD.Pro is used extensively by engineers across the world. Different engineers have different requirements and see benefits in their software in different places. What is of significant value to one, may be of less value to another. We clearly aim to provide value to as many as possible. If you do not see so much value then please be aware that many others do. What we also appreciate is the great ideas engineers have to add value in their sector and regularly post in the Ideas portal. By having others vote to support their ideas pushes up the idea and can get added to the development backlog. I would suggest you post some of your ideas there and get others to support you and vote for them.
This update has broken report generation in our entire office. It doesn't matter the load combinations you select, it will display results for all of them, including the basic ones. Updates are supposed to fix items. Please do proper QA before releasing. We are switching back to Update 8 until it get resolved.
I agree with Saady, the fact that you can not select or exclude load cases in report generation has made the report function useless for any practical use of the report generator. This must be corrected as soon as possible.
One noticeably bug in this release; it's the basic wind speed of ASCE-7 wind load. It keeps resetting to 180 mph even kph unit was selected. The user can't even change the value. However, in the std file it changes when the value is changed.
