Coffee Corner: STAAD - Mass Modeling using Reference Loads
Title: Coffee Corner: STAAD - Mass Modeling using Reference Loads
Presenter: Sabrina Tedeschi, Senior Application Engineer, Bentley Systems
Date: Thursday, April 21, 2022
Time: 01:00 PM Eastern Daylight Time
Register Now!
This one-hour session includes a technology presentation on how to model masses using a reference load case in STAAD.Pro, as well as time to share questions. You will learn:
  • Generating Masses
  • Understanding how Masses will be used by the Program
Mark your calendar and invite your colleagues to April’s STAAD Coffee Corner virtual workshop.
Bentley STAAD Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an Gdible level so you can hear the presenters.  Help
