Title: Coffee Corner: Structural - SEAPAC - RC Column-Beam Joint Check for Special Moment Frames
Date: Wednesday, March 15, 2023
Time: 11:00 AM India Standard Time
Presenter: Nidhi Valia
Register Now!
The topics in this session include, the column-beam joint check and the shear check that are performed in STAAD Advanced Concrete Design for ductile columns and special moment frame columns.
The design of beam-column joints is an important part of earthquake resistant design for reinforced concrete moment-resisting frames. Due to the difficulty of repairing and retrofitting damaged beam-column joints in buildings after a seismic attack, recent building codes for reinforced concrete buildings, provides allowable joint shear stress to preclude premature failure of beam-column joints before a beam sway mechanism has developed.
This check is performed for different concrete design codes such as:
Bentley Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
