RAM Concept's "K Factors"
I need a little help understanding a the stiffness factors in RAM Concept. Is "KMr" the same as the "Strong-axis stiffness"?? Why doesn't the RAM Concept Manual give a graphic representation or a numerical explanation of these factors? Please help. Thanks in advance.
Parents Reply
  • Slight clarification; the direction of the slab objects is defined by the user with the R axis. The default of 0 degrees for the R axis corresponds to the positive global X axis, but slab objects can be rotated (counter-clockwise) in plan.
    KMr is a stiffness variable for moments about the R axis. Section 17.20 Slab area properties explains best.
    Note, throughout the program we use R and S when referring to the local axis of an object (slab, beam, wall, column) and X and Y for reference to the global axis.
