Is there anyone tell me why the following error appeared?
the attached is the staad pro file.
for MVXR MK4.std
Since joint weights and self weights should be given as mass. Remove the sign convection and try
Bubalan Sundaram
Tokyo
Answer Verified By: Tan Hong Koo
All the nodes of your model have the same Y coordinate as the supports. So, there are no nodes above the base of the structure on which to distribute the base shear. In the UBC code, you will find a section titled vertical distribution of seismic forces. That section cannot be applied if all the components of the structure are at a single level.
