Query on time history analysis of 80 storied building
I had few questions written below on Dynamic analysis. I will be obliged if somebody could help me on this issues.
Awaiting for your reply.
Paul
Below is my example of input file where I put my questions by star marks(*)
STAAD SPACE
JOINT COORDINATES
1 0 0 0; 2 3 0 0; ..........
MEMBER INCIDENCES
1 6 7; 2 7 8; ............
DEFINE MATERIAL START
END DEFINE MATERIAL
MEMBER PROPERTY
1 TO 325 PRIS YD 0.3 ZD 0.2
MEMBER PROPERTY
326 TO 365 PRIS YD 0.3 ZD 0.3
CONSTANTS
MATERIAL CONCRETE ALL
SUPPORTS
1 TO 5 .... FIXED
DEFINE TIME HISTORY
TYPE 1 FORCE
**** What values should I put for time vs force for 80 story or more?**************
1 100 2 200 3 300
ARRIVAL TIME
**** What values should I put for arrival time for 80 story or more?**************
0 1 2 3
DAMPING 0.05
LOAD 1 D+L
LOAD 2 WIND
JOINT LOAD
LOAD 3 DYNAMIC LOADS
********* SHALL I PUT DEAD, LIVE & WIND FORCE IN ALL THREE DIRECTIONS?******************
SELFWEIGHT X 1
SELFWEIGHT Y 1
SELFWEIGHT Z 1
MEMBER LOAD
1 TO 20 ...226 TO 325 UNI GX 3
1 TO 20 ...226 TO 325 UNI GY 3
1 TO 20 ...226 TO 325 UNI GZ 3
JOINT LOAD
6 11 16 21 26 36 41 46 51 56 66 71 76 81 86 96 101 106 111 116 126 131 136 -
141 146 FX 2.1
141 146 FY 2.1
141 146 FZ 2.1
TIME LOAD
**** What values should I put for time load for 80 story or more?**************
1 TO 150 FX 1 1 1.000000
**********What will be the load combinations for DRIFT for dynamic analysis for wind?************
LOAD COMBINATION 4
1 0.7 2 0.7
LOAD COMBINATION 5
1 0.7 3 1.0
PERFORM ANALYSIS
FINISH
  • What kind of a dynamic load are you looking to apply? A vibrating load due to machinery on one of the floors? Or a ground excitation due to an earthquake?
    Either way, the type of building isn't really going to affect the application of the load. For applying a seismic load, see example 29 of the examples manual. For applying a load induced by vibrating machinery, see example 22 of the same manual. If it is a randomly varying force, see example 16.
    Unfortunately, all of the above examples show the specification of the data thru the text file only. There are no examples that show how to assign this data using the STAAD GUI. If you face any difficulty assigning them thru the GUI, let us know.
    Also, if it is a 80-storey building, the size of the model could be so large that, coupled with the significant computing resources needed for a time history analysis, you may face difficulties in getting the analysis to be completed. If so, you may have to consider reducing the model size.
    Answer Verified By: Anand Paul
