To determine plate thickness in tie down plate model, which values I should use to calculate actual plate stress and compare with allowable stress? Please see my attached pdf.
Thank you
Staad123
For option 1 mentioned in your PDF file, you need the stress denoted as MAX ABSOLUTE which is described here
communities.bentley.com/.../11097.max-absolute-stress-in-plate-contour-page-for-plate-elements.aspx
For checking the out-of-plane effects, you need to look at the terms
axial + bending :
Top Combined SX
Top Combined SY
Bottom Combined SX
Bottom Combined SY
out-of-plane shear :
SQX and SQY
