Time History Analysis Results - Member forces
Can someone give some clarification about the issue below?
In Section 5.31.4 of the STAAD.Pro Technical Reference Manual, in the Notes it says that for a Time History Analysis
"b Results are the individual maximums over the time period. Thus, derived quantities such as section forces and stresses, plate surface stresses and principal stresses should not be used".
Does this mean that the results for member forces in the postprocessing mode are onerous?
Could you respond  ASAP to this query please?
Kind Regards,
Skerdi
  • Hello ,
    Sorry Kris could you give me some help with the issue above?
    Also some quick thoughts about combining the DIRECT ANALYSIS with Time History loads - is it possible? Is the Direct analysis used as a direct substitute of the PERFORM ANALYSIS command?
    In the link below there is given a workaround for P-Delta analysis for Time History loads, but I am not sure how it would work for the DIRECT ANALYSIS method.
    http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/p/22867/51141#51141
    Your help would be much appreciated.
    Kind Regards
    Skerdi
  • Results like nodal displacements, support reactions, beam end forces are all correct in a time history analysis. However you need to remember that like the other items in a time history analysis, beam end forces are also individual maximums and may not be occurring at the same instant of time. Since intermediate section forces are derived based on the beam end forces, so it does not make sense to derive these based on quantities that do not coexist. Similar logic applies for derived stresses too. The note explains the same.
  • Hello Sye,
    Thank you for your quick reply.
    Another quick question if it is possible: the problem is that I am combining the Time History loads with the Static loads in a LOAD COMBINATION. In this case the result for the combination may be not the maximum, e.g. say that the static displacement result in Z direction for a certain node is +20mm, and for the dynamic load the displacement ranges between (-15mm and +10mm). The software will pick the highest magnitude for the dynamic load, i.e. -15mm; therefore, the combined result will be (+20)+(-15) = (+5mm). This is wrong because the most severe case would have been (+20)+(+10) = (+30mm). Is this interpretation right? How do I overcome this?
    I) One idea might be to crate 2 combinations 1. static + dynamic, and 2. static - dynamic, and take the maximum results (deflections and forces) for each member out of the 2 cases. Is this right?
    II) A second idea is to get first the displacements for the dynamic load only. There is an option where you can get the displacements (only displacements not forces) for the dynamic load in every time step. I guess for the time steps the results are realistic, not the maximums (maybe this has to do with the length of the time step, the smaller the better it is), can you confirm? Then after getting the results from static I can assess the best combination for the static and dynamic displacement.
    Do you have any other suggestion and what would your comments be for my proposed methods?
    Thank you a lot for your time.
    Best Regards,
    Skerdi
  • Yes, as you mentioned in point 1, one should use 2 combinations to capture the worst effect.
    Regarding your point 2, first of all I would like to mention that it is possible to capture not only displacements but also member forces and support reactions at each instant of time. You can choose the SAVE option when defining the time history definition and that would save the member forces and reactions in a separate file by the name “model_name.frc” within the same folder where the model is. You can always browse that file to find out forces at any instant and as you said, these are not maximums but real time data. You can assess the worst effect. However this would be quite a task for a reasonably sized model and so personally, I would prefer to go with option 1.
    Answer Verified By: Andi
  • Thanks a lot Sye, You were very helpful indeed.
    Kind Regards,
    Skerdi
