I am using RAM SS Concrete Shear Wall module and keep getting an error in my wall piers. The piers keep failing according to the maximum spacing requirements of 19.5.5.4. But the "actual spacing" noted in my section cut analysis is not consistent
The piers keep failing according to the maximum spacing requirements of 19.5.5.4. But the "actual spacing" noted in my section cut analysis is not consistent with the amount of reinforcing
I manually put in the pier. How is it calculated?
Parents Reply Children
