Modify AISC Safety Factors
I am doing a Blast design on STAAD.Pro, and according to our basis of design the safety factors should be 1.0.
I am using AISC 360-05: ASD as the design code. The question is how can I change the safety factors for all Tension-Compression, Flexure and shear to 1.0? STAAD uses a factor of 1.67 as a default.
Thank you for your help.
