Good day,
I am quite often stuck with the 'failure' section results in non critical shear zones of the beam (e.g. 2-3 m away from support). Software simply ignores the transverse reo it has designed and sets Vus=0 (see below). What is the reason for that?
Can you please attach your file to the post or share your model using our Secure File Upload using the instructions on the following web page:
http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload
It seems this is still an issue. I have version 8.02.00.146 and it seems to be ignoring all my reinforcement even when I have assigned a tighter spacing than what the calcs say is required.
