while transferring transfer loads to Ram Concept I have a notice coming out that dynamic transfer loads are ignored (see below)
please, advise solution to fix the issue
Dynamic load cases are currently not imported into RAM Concept. See information on the following web page for more information on this and other limitations:
http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/importing-items-into-ram-concept-tn
One possible work around is to create an equivalent static seismic load case with user defined story forces that are based on the difference in the building story shear reported in the Building Story Shear Report in RAM Frame. This approach is discussed briefly in the frequently asked question, "Why don't the values reported for the building story shear correspond to the values reported for the change in story shear?" on the web page below:
http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/4029.ram-frame-dynamic-analysis-faq
any updates to this issue in recent versions of Concept
