Any advice for the determining the rhythmic excitation of monumental stairs? I have a cantilevered stair that I'm worried about. I have a copy of Davis & Murray's 2009 "Slender Monumental Stair Vibration Serviceability" paper which recommends a natural frequency greater than 10hz.
My initial thought was to call the landing a rigid diaphragm and assign the mass of the floor to one node. This is not accurate, however, because it ignores any mass contribution from the treads and risers. The next option would be to assign mass to each node at a tread/stringer intersection as well as at the nodes defining the landing. If i take this approach should I remove all rigid diaphragm constraints? I was not planning on modelling any slabs, or the treads/risers, but if that would better determine the frequency I certainly could.
Next, what is the forcing function used to determine the dynamic response? Should I be entering data in the response spectrum input tab? If I don' t, what is being used? Or should I be using the "earthquake acceleration" tab to be entering info? I know SRSS doesn't use damping and CQC does, is there an advantage to one over the other?
Finally, when I'm running under my assumptions ( mass at all nodes, no data entered for response spectrum or acceleration) I'm getting very large nodal displacements (i.e. 9") Could this truly be correct? Gravity vertical displacements at the maximum point of radius are about .25". I'm also getting a fundamental frequency of 6.67hz which seems to be in range for the current sizes chosen.
Thanks for any and all guidance on this topic.
The response spectrum (acceleration and time data) is irrelevant if you only want the natural frequencies, but in Ram Elements something must be entered for the dynamic analysis to run. Depending on what you enter for the rsp, the scale factor and the direction, that's all going to impact deflections for that load case, but again, it does not matter if you are only after the frequencies. As to the mass distribution, that's really up to you. If you are going to lump the masses to a point and use a diaphragm, then it's important to enter the mass moment of inertia (rotation about Y mass in Elements) as well. If you spread the masses to various nodes and forego the diaphragm, then MMI is less important. Modeling the treads would not impact behavior if they are all parallel and pinned, but if they are modeled with fixed ends, they would alter the stiffness significantly.
Thanks Seth,
I'm still unclear as to what is forcing the vibration if nothing has been entered (except mass)?
Also - are the displacement values shown on the screen inches or some other measurement? I assumed they were inches, but the output report indicates "phi":
In your estimation, should mass be entered in all 6 degrees of freedom to more accurately find the natural frequency? Without a rigid diaphragm (which is the correct assumption based on stair assembly/slope) if I don't have a MMI entered, it will not find any rotational modes. How would I find the MMI without diaphragms? I can do the hand calc to distribute the dead load to nodes as masses.
Edit: without a diaphragm there really is no "rotation", so any displacements of nodes are translational. I therefore am applying the mass in all 3 degrees of freedom there.
Answer Verified By: TLiebhold
