I'm a long time RamSteel user, but I'm just starting to use the RamConcrete module. I'm using the program to do a load takedown for a very large, irregular footprint building. RamConcrete seems to have a nice feature/button that shows the base reactions at the columns, however I can only get it to show reactions for individual load cases - i.e. DL alone, unreducible LL alone etc. Is there a way to have RamConcrete show results for a simple combined load case, like DL+LL?
Jimmy S.
The analysis in RAM Concrete only looks at individual load cases similar to RAM Frame mode Analysis. The design modules consider load combinations but do not report column reactions.
