Ram Concept: Capacity differences between two the same beams due to strip defined - not consider as PT vs consider as PT
I know that Ram Concept is not taking into Strength design tendons when in the strip definition consider as PT is not checked but:
Why Capacity is different in to the same beams ( the same class of conrcrete, amount of reinfocement and tendons) ? Capacity does not depend normally on tendon, tendon is just external loading. Amount of reinfocement depends on capacity of element. Here are screenshots of my problem: Bending Moment Capacity and Vertical Shear Capacity.
Thanks for Your help.
Best Regards
BK
Parents Reply Children
