How to applying moving load on a beam which is not parallel to any axis in the plane?
I have a beam in the XZ plane, but it is neither pararell to X nor Z axis. I have to apply a moving load to that beam. Is that possible? Since staad only asks for increments in the x or z axis. If not then is there any work around? Pls find attached picture. The beam in question is the beam highlighted in red.
Thanking you all in advance,
Debayan
