Member Check to AISC 360-10 and AISC Design Guide 9
Hi, I have some questions regarding member check to AISC 360-10.
So I was doing some check on a simple member (attached output file), and then I checked it using hand calculation to verify the numbers (I need to know how the program do simpler problem before doing harder analysis not solvable by hand) and found some problem.
1. I came into the conclusion that the check for minor axis shear (Z-axis) uses shear area Aw of 4/3 bf*tf (width and thickness of flange) while the code suggests bf*tf (section G7). Is this intentional? And if it is, please sugggest the reasoning behind the 4/3 factor.
2. While doing the check for torsion, I also came to the conclusion that the formula that is used to calculate pure flexure shear stress at flange-web junction to be a bit weird, as I think the shear stress should be obtained by dividing the contribution by strong axis shear by the thickness of the web, and weak axis shear by the thickness of the flange, not otherwise (see below picture). Again please suggest the reasoning behind this, or if I used the wrong formula.
Thank you.
        PAGE NO.    1
             *           STAAD.Pro V8i SELECTseries5            *
             *           Version  20.07.10.65                   *
             *           Proprietary Program of                 *
             *           Bentley Systems, Inc.                  *
             *           Date=    APR 15, 2015                  *
             *           Time=     9:51:36                      *
             *      USER ID: EMAS                               *
     1. STAAD SPACE
INPUT FILE: S2.STD
     2. START JOB INFORMATION
     3. ENGINEER DATE 10-APR-15
     4. END JOB INFORMATION
     5. INPUT WIDTH 79
     6. UNIT METER KN
     7. JOINT COORDINATES
     8. 1 0 0 0; 2 0 14.9998 0
     9. MEMBER INCIDENCES
    10. 1 1 2
    11. DEFINE MATERIAL START
    12. ISOTROPIC STEEL
    13. E 2.05E+008
    14. POISSON 0.3
    15. DENSITY 76.8195
    16. ALPHA 1.2E-005
    17. DAMP 0.03
    18. TYPE STEEL
    19. STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
    20. END DEFINE MATERIAL
    21. MEMBER PROPERTY AMERICAN
    22. 1 TABLE ST W24X192
    23. CONSTANTS
    24. MATERIAL STEEL ALL
    25. SUPPORTS
    26. 1 2 FIXED
    27. LOAD 1 LOADTYPE NONE  TITLE LOAD CASE 1
   **WARNING** - ALL DEGREES OF FREEDOM FIXED.
   STAAD WILL INFINITESIMALLY RELEASE MOMENT-X AT FIRST JOINT ENTERED.
    28. MEMBER LOAD
    29. 1 CON GY 300 5 0
    30. 1 CON GX -75 5 0
    31. 1 CON GZ 25 5 0
    32. 1 CMOM GY 35 5 0
    33. PERFORM ANALYSIS PRINT ALL
     STAAD SPACE                                              -- PAGE NO.    2
            P R O B L E M   S T A T I S T I C S
     NUMBER OF JOINTS          2  NUMBER OF MEMBERS       1
     NUMBER OF PLATES          0  NUMBER OF SOLIDS        0
     NUMBER OF SURFACES        0  NUMBER OF SUPPORTS      2
           SOLVER USED IS THE OUT-OF-CORE BASIC SOLVER
     ORIGINAL/FINAL BAND-WIDTH=     1/     1/      1 DOF
   TOTAL      PRIMARY LOAD CASES =     1, TOTAL DEGREES OF FREEDOM =       1
   TOTAL LOAD COMBINATION  CASES =     0  SO FAR.
     SIZE OF STIFFNESS MATRIX =        0 DOUBLE  KILO-WORDS
     REQRD/AVAIL. DISK SPACE  =     12.0/    675.0 MB
     STAAD SPACE                                              -- PAGE NO.    3
   LOADING     1  LOADTYPE NONE  TITLE LOAD CASE 1
   MEMBER LOAD - UNIT KN   METE
   MEMBER     UDL      L1     L2      CON       L     LIN1     LIN2
      1                           300.0000 GY   5.00
      1                           -75.0000 GX   5.00
      1                            25.0000 GZ   5.00
      1                             35.000 GY    5.00  CONCENTRATED MOMENT
FOR LOADING -     1
APPLIED JOINT EQUIVALENT LOADS
 JOINT   FORCE-X     FORCE-Y     FORCE-Z      MOM-X       MOM-Y       MOM-Z
     1-5.55551E+01 1.99999E+02 1.85184E+01 5.55548E+01 2.33332E+01 1.66664E+02
     2-1.94449E+01 1.00001E+02 6.48163E+00-2.77780E+01 1.16668E+01-8.33339E+01
          STATIC LOAD/REACTION/EQUILIBRIUM SUMMARY FOR CASE NO.     1
           CENTER OF FORCE BASED ON X FORCES ONLY (METE).
         (FORCES IN NON-GLOBAL DIRECTIONS WILL INVALIDATE RESULTS)
                        X =  0.000000000E+00
                        Y =  0.500000001E+01
                        Z = -0.466666709E+00
           CENTER OF FORCE BASED ON Y FORCES ONLY (METE).
                        X =  0.277768515E+00
                        Y =  0.500000025E+01
                        Z = -0.925895147E-01
           CENTER OF FORCE BASED ON Z FORCES ONLY (METE).
                        X = -0.140000015E+01
                        Y =  0.500000040E+01
                        Z =  0.000000000E+00
TOTAL APPLIED LOAD     1
   ***TOTAL APPLIED LOAD ( KN   METE ) SUMMARY (LOADING     1 )
       SUMMATION FORCE-X =         -75.00
       SUMMATION FORCE-Y =         300.00
       SUMMATION FORCE-Z =          25.00
      SUMMATION OF MOMENTS AROUND THE ORIGIN-
      MX=         125.00  MY=          35.00  MZ=         375.00
     STAAD SPACE                                              -- PAGE NO.    4
TOTAL REACTION LOAD    1
   ***TOTAL REACTION LOAD( KN   METE ) SUMMARY (LOADING     1 )
       SUMMATION FORCE-X =          75.00
       SUMMATION FORCE-Y =        -300.00
       SUMMATION FORCE-Z =         -25.00
      MX=        -125.00  MY=         -35.00  MZ=        -375.00
   MAXIMUM DISPLACEMENTS (  CM  /RADIANS) (LOADING      1)
             MAXIMUMS    AT NODE
      X =  0.00000E+00       0
      Y =  0.00000E+00       0
      Z =  0.00000E+00       0
      RX=  4.91696E-08       1
      RY=  0.00000E+00       0
      RZ=  0.00000E+00       0
   EXTERNAL AND INTERNAL JOINT LOAD SUMMARY ( KN   METE )-
   JT     EXT FX/   EXT FY/   EXT FZ/    EXT MX/    EXT MY/    EXT MZ/
          INT FX    INT FY    INT FZ     INT MX     INT MY     INT MZ
        SUPPORT=1
     1    -55.56    200.00     18.52      55.55      23.33     166.66
            0.00      0.00      0.00       0.00       0.00       0.00  111111
     2    -19.44    100.00      6.48     -27.78      11.67     -83.33
   ************ END OF DATA FROM INTERNAL STORAGE ************
    34. PARAMETER 1
    35. CODE AISC UNIFIED 2010
    36. METHOD ASD
    37. BEAM 1 ALL
    38. CB 1 ALL
    39. FLX 1 ALL
    40. FU 410000 ALL
    41. FYLD 245000 ALL
    42. STP 1 ALL
    43. TORSION 1 ALL
    44. TRACK 2 ALL
    45. CHECK CODE ALL
STEEL DESIGN
     STAAD SPACE                                              -- PAGE NO.    5
                       STAAD.PRO CODE CHECKING - ( AISC-360-10-ASD)   v1.3a
 ALL UNITS ARE - KIP  INCH (UNLESS OTHERWISE Noted)
  -------------------- START OF DESIGN OUTPUT OF MEMBER      1 --------------------
 *MEMBER NO:     1    CRITICAL RATIO:  1.207(FAIL)     LOAD:     1
  LOCATION (ft): 0.00  CONDITION: Eq. H3-7
  SECTION: ST   W24X192                 (AISC SECTIONS)
  UNIT: KIP FEET
  STRENGTH CHECKS:
  CRITICAL RATIO:  1.207(FAIL)     LOAD CASE:     1  LOCATION (ft): 0.00  CONDITION: Eq. H3-7
  DESIGN FORCES:   Fx:     44.96(T)    Fy:   -12.49      Fz:     -4.16
                   Mx:  -1.72E+01      My:  4.10E+01     Mz:  -1.23E+02
  SECTION PROPERTIES:       AZZ:      25.209 AYY:      20.631 CW:      76383.609
                            SZZ:     491.559 SYY:      81.853
                            IZZ:    6260.000 IYY:     530.000
  MATERIAL PROPERTIES:      FYLD:       35.534   FU:       59.465
  ACTUAL MEMBER LENGTH(ft):    49.210
  PARAMETERS:                  KZ:  1.000  KY:  1.000  NSF:  1.000  SLF:  1.000  CSP:  1.000
  SLENDERNESS:   ACTUAL SLENDERNESS RATIO:     192.472  LOAD:     1   LOC.(ft):   0.000
                 ALLOWABLE SLENDERNESS RATIO:  300.000
  SECTION CLASS:  FLANGE:/            l:          lp:        lr:
                  WEB:
  COMPRESSION:    Non-Slender       4.435        N/A     16.199
                  Non-Slender      27.840        N/A     43.100
  FLEXURE:        Compact           4.435     10.992     28.926
                  Compact          27.840    108.763    164.880
  TENSION:        FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  YIELDING:       44.961    1197.951      0.038    Eq. D2-1           1        0.000
  RUPTURE:        44.961    1673.953      0.027    Eq. D2-2           1        0.000
     STAAD SPACE                                              -- PAGE NO.    6
  COMPRESSION:    FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  MAJOR:          22.481    1021.885      0.022    Eq. E3-1           1       49.210
  MINOR:          22.481     234.202      0.096    Eq. E3-1           1       49.210
  INTERMEDIATE:   Ag:       KL/r:        Fcr:      Fe:          Pn:
  MAJOR:          56.300     56.004       30.312     93.561     1706.548
  MINOR:          56.300    192.472        6.947      7.921      391.117
  FLEX TOR BUCK:  FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
                  22.481     941.262      0.024    Eq. E4-1           1       49.210
  INTERMEDIATE:   Ag:       Fcr:         Pn:
                  56.300     27.920     1571.908
  SHEAR:          FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  MAJOR(VZ):       4.163     321.834      0.013    Eq. G2-1           1        0.000
  MINOR(VY):     -12.489     293.239      0.043    Eq. G2-1           1        0.000
  INTERMEDIATE:         Aw:       Cv:          Kv:       h/tw:        Vn:
  MAJOR(VZ):          25.209     1.000        1.200     4.435       537.463
  MINOR(VY):          20.631     1.000        0.000    27.840       439.858
  UNIT: KIP FEET
  YIELDING:       FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  MAJOR:        1.23E+02    9.91E+02      0.124    Eq. F2-1           1        0.000
  MINOR:        4.10E+01    2.23E+02      0.183    Eq. F6-1           1        0.000
  INTERMEDIATE:   Mnr:       My:       Cb:
  MAJOR:        1.66E+03    0.00E+00   1.000
  MINOR:        3.73E+02    0.00E+00   1.000
  UNIT: KIP FEET
  LAT TOR BUCK:   FORCE:    CAPACITY:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  MAJOR:        1.23E+02    6.57E+02      0.187    Eq. F2-2           1        0.000
  INTERMEDIATE:   Mn:       Me:         Cb:       Lp:       Lr:       Lb:
  MAJOR:        1.10E+03   0.00E+00     1.000     13.016    54.296    49.210
  UNIT: KIP FEET
  INTERACTION:    RATIO:    CRITERIA:    LOAD CASE:   LOCATION(ft):
  FLEXURE COMP:    0.370    Eq. H1-1b          1        0.000
  FLEXURE TENS:    0.389    Eq. H1-1b          1        0.000
  INTERMEDIATE:   Mcx:        Mcy:        Mrx:        Mry:        Pc:        Pr:
  FLEXURE COMP:   6.57E+02    2.23E+02    1.23E+02   4.10E+01    234.202      0.000
  FLEXURE TENS:   6.57E+02    2.23E+02    1.23E+02   4.10E+01   1197.951     44.961
     STAAD SPACE                                              -- PAGE NO.    7
  UNIT: KIP FEET
  IN PLANE FLEX:    0.044    Eq. H1-1b          1       41.008
  OUT PLANE FLEX:   0.072    Eq. H1-2           1       41.008
  INTERMEDIATE:   Pc:        Pr:        Mc:        Mr:
  IN PLANE FLEX:  1.02E+03   1.12E+01    657.052     25.609
  OUT PLANE FLEX: 2.34E+02   1.12E+01    657.052     25.609
  -------------------- END OF DESIGN OUTPUT OF MEMBER      1 --------------------
  ****** AISC DESIGN GUIDE 9 ******
  MEMBER:     1 SECTION: W24X192                  AISC
  END CONDITION: FIX-FIX
  SHEAR CAPACITY:   12.77  SHEAR CRITERIA:  Eq. H3-8
  NORMAL CAPACITY:  21.28  NORMAL CRITERIA: Eq. H3-7
  STRESS LOC  SHEAR  RATIO  LOAD CASE/ | STRESS LOC   NORMAL RATIO  LOAD CASE/
                            SECTION    |                            SECTION
  MID FLANGE    0.78   0.06       1    | FLANGE EDGE   25.67   1.21       1
                               0.00    |                               0.00
  FL-WB JUNC    6.38   0.50       1    |
                               0.17    |
  MID WEB       3.72   0.29       1    |
                               0.17    |
  PURE TORSION SHEAR STRESS   CRITERIA: DG9 Eq. 4.1
  FLANGE EDGE:   5.43  WEB EDGE:    3.01
  WARPING SHEAR STRESS        CRITERIA: DG9 Eq. 4.2a
  MID FLANGE:    0.73
  WARPING NORMAL STRESS       CRITERIA: DG9 Eq. 4.3a
  FLANGE EDGE:   15.87
  PURE FLEXURE SHEAR STRESS   CRITERIA: DG9 Eq. 4.6
  MID FLANGE:   0.05  FLANGE-WEB JUNC:   0.61  MID WEB:    0.71
  DIRECT AXIAL BENDING STRESS CRITERIA: DG9 Eq. 4.5
  FLANGE EDGE:    9.81
    46. FINISH
     STAAD SPACE                                              -- PAGE NO.    8
             *********** END OF THE STAAD.Pro RUN ***********
               **** DATE= APR 15,2015   TIME=  9:51:41 ****
         *   For technical assistance on STAAD.Pro, please visit    *
         *   http://selectservices.bentley.com/en-US/               *
         *   Details about additional assistance from               *
         *   Bentley and Partners can be found at program menu      *
         *   Help->Technical Support                                *
         *      Copyright (c) 1997-2014 Bentley Systems, Inc.
         *                http://www.bentley.com                    *
Parents Reply Children
