Hi
I have tried using the shear wall module after analyzing the whole building in RAM Frame. After analysis being done for shear wall group in the basement level I constantly get the result where 2 vertical sections are passing but 2 horizontal sections are failing (even if reo is increased). Summary page says FAIL but every parameter checked for the wall is OK.
File with the name "111" is uploaded.
Please advise
I'm using latest RAM SS and AS3600 code. See the summary I'm getting from the software below:
