RAM Frame - Combined loads output for Bracing Members
Is there an option to output factored axial forces for vertical bracing to DXF output a bit like displaying end reactions for beams?  Its very laborious to either to print off the member forces or use the view / update command and view analysis output for the worst case member forces.
