Hi all,
I have atached a staad model for a wall mounted bracket. which supports OLE column. column was modelled seperately using other software and reactions are applied on this bracket.
I found member no. 53 is failing in Huge compression. If i cahnage section to higher one, other members start failing.
Can you please guide me what went wrong?
Thanks in advance.
47073914-SW-CV-CALC-MOD-105-R2.std
Answer Verified By: Mahesh Gopal
