When I try to run the RAM Concrete shear wall module, I am getting an error when I click view/update about "RAM Container MFC Application". How do I fix this issue and allow the RAM Concrete Shear Wall module to function correctly?
Try deleting and re-assigning the section cuts.
If you have coupling beams, you can also try toggling them off and on again.
If that does not help, make sure your Ram Frame analysis results are current and OK. You can check deflected shapes or member forces to make sure the data is all reasonable for this.
Otherwise, please post your model using the Secure File upload link below left and let us know what version you are using.
