I am trying to use RAM Structural System to design an apartment building out of Steel and Wood. The wood beams are modeled as steel joists (I have custom joist tables set up for the wood beam members). The steel beams are modeled as steel beams. Both the wood posts and the steel columns are modeled as steel columns. I am trying to create a custom connection spreadsheet that calculates wood connections using the reactions from the joists in RAM. Does RAM Structural System have a report that shows what each beam/joist frames into (column vs beam)? I am aware of the framing check report and the connection report inside of RAM, but neither gives you the member that the beam frames into unless it is shallower (and I don't think they work with joists). If there is no report, is it possible to use DataAccess to pull this information out of the model?
Eventually, I would want the spreadsheet to tabulate the following information for each joist on each floor of the building (Consider the situation where Joist "A" frames into either the side of Joist "B" or sits on Column "C"):
Level
Joist "A" Number
Joist "A" Size
Left Joist "A" Reaction
Left Joist "B" Size -OR- Column "C" Size
Left "Beam" -OR- "Column"
Right Joist "A" Reaction
Right Joist "B" Size -OR- Column "C" Size
Right "Beam" -OR- "Column"
With this information, I could write a spreadsheet that sizes each unique connection configuration/reaction. I would appreciate any insight you could provide. Thank you.
Answer Verified By: Tom Curry
